Can this only be done at renault or can I use my local tuning/performance centre that carries out all of my other work and who I trust 100%. I believe someone said that you need a special tool that only renault has!
You need the right tools it can be difficuly (space for a starter) loads of engines have been ruined when people (and garages) have done it on the cheap or set the cams out slightly and the performacne has taken a hit.
Pm me your email addres and I'll send you the file on how to do it if you want.
Cheers guys!
Is it just the belt that needs replacing or is there anything else!
I have heard people talk about the auxilary belt, should this be done as well?
get the timing tensioner and idler pulleys replaced as well and yes will need new auxillary belt.
get a timing belt kit , auxillary belt, cam end covers
where are you located ? as im sure someone on here can recommend someone close to you to do the job
