Mk1 1.4RT
Hey guys
I have a Mk1 Phase 3 Clio 1.2, without central locking.
It was broken into recently and i have bought a set of replacement locks. I've fitted them all bar the ignition switch which i want to replace to avoid having 2 keys.
I've tried to remove the ignition switch but the spring clip seems jammed. I've connected the new ignition to test it but the engine will only tick over and not fire, which i'm guessing is due to the immobiliser.
Should the new ignition switch work if i swap the just the lock part of it not the switch, or is it more complicated than that? Since the current ignition switch seems jammed i need a definitive answer before i attempt to replace it.
Any help would be appriciated.
Phil
Phil
