Mk1 F4R conversion - Batt. Light
Car  Mk1 Clio F4R'd
Hi guys,
Cars up and running. Just a little annoying problem which i dont know how to fix. Battery light is on when the car is on, but down not come on when the ignition is on. Flickers on and off when the car has been given some.
The alternator has been checked and the car has been running for a while with no problems.
Any ideas?
God knows, the one from the track car and there wasnt this problem with that. Any ideas how to check quickly?
Its just a problem thats slightly irritating lol
Either bad earth or wired upto the wrong pin on the alternator (if its a Mk1 2 pin connector on the alt)
At the end of the day its only a warning to say if the alt isnt charging properly really, just a signal wire connected up wrongly it sounds like
Yeah true, i know its working fine as its been left running and so on.
I'll look into it at some point, cheers bud. Dont forget that guide for the dials ;) i need a speedo that goes past 130 and with a rev counter
Its already done, just need to confirm one ECU pin when I get a minute. Il get it finished tomorrow probably
