MK1 F4R Help
Car  F4R'd Mk1 Clio
Been doing a f4r conversion in a mk1.
The donor was a 172cup
So bought a cable throttle body but it wont fit on the side of the inlet manifold.
Do I just need to buy any old phase1 inlet manifold or is there a certain one I need (being french I suspect there may be more than 2 types of inlet manifold)
Any help much appreciated
They PH-1 and PH-2 manifolds fit slightly different on the throttle body...
Buy a PH-1 upper inlet manifold :)
or do as others have done and redrill the ph2 op inlet to fit the cable body..
how are you running the engine? the looms and half the top sensors are completely diffeent and the ecu programming obviously different?
Wayne
