MK1 Ph1/2 lights in a Ph3?
Car  Black PH2 172 FF
Has anyone put Phase 1/2 headlights in their Phase 3?
Is it a straight swap?
And does the headlight adjuster thing still work?
(Cause I'm putting a valver bonnet on soon :cool: )
Thanks!
word_easy said:
thanks for your reply...not
its common sence
Changing my bonnet and lights is not backdating my car!
It's personal preferance.
If you are not going to help with my question, why bother posting a reply?
Typical 'forum user' waste of time........:argue:
Gray said:
Yes the will fit straight in, but you would need different wings aswell wouldnt you?
Thanks mate - a straight answer LOL
I'm getting 16v wings soon, but according to my local Renault, the part number for standard wings on a ph2 is the same as the part number for a ph3! So according to them they will fit!
Nope.
You can still adjust under the bonnet (although, you *may* have to drill a hole - I remember someone on about not being able to get to it after the conversion.). You will have to look at a set of headlights, and see where you have holes.. and if they match up :)
The interior adjustment isn't tested as far as I know (they've never tested mine, ever)
Daz said:
Nope.
Cheers mate
Thanks for your help! :D
