MK1 Phase 1 Clio
hello,
a few questions for you all......
..1) will 16v seats fit into a MK1 Phase 1 Clio
..2) will the RT bumpers fit onto a MK1 Phase 1 Clio
..3) is NOS likely to kill off a 1.2 MK1 Phase 1 Clio
cheers Dave.
Well im sure theyd have the same attachment points as it wouldnt be cost effective for Renault to change them for ph2 and ph3 models.
I would only use 50bhp max for the NOS.
1. yes to the first one
2. phase 2 and phase 1 rt bumpers are the same only rear lights and trim that differs. phase 3 bumpers will even fit.
3. yes will go pop
1 & 2 everybody has said already
3> Will NOT go pop if you engine has no original manufacturing or faults from its service. As long as you set it up correct;y and dont fire it from idle or really below 3000rpm, then you wont ever have a problem. N20 is perfectly safe at these small amounts.
