MK2 172 HEADLAMP
anyone taken one out ? dont ask why but i need to take mine out and other than the bolt at the top is there anything else i need to undo/remove to get the fecker out?
  320d M Sport
are they not gas filled? i thoiught about trying to clean the inside on mine.....then changed my mind, i know they cost over £200 EACH!
nah they arent even sealed, just need to remove the whole headlamp from the car as i had what you might call a mishap, not broken or anything just need to take it out
went to fit my piaa led side light bulbs as the standard ones look sh*te and yellow next to the xenons and the slippery little fecker slipped out of my hand into the headlamp and i cant get it out on the car so i need to take the lamp out :oops: oops, or to quote homer DOH !!!!!!!!!!
  Clio 1.6 16V
Sh*t luck. Cant you try and seal a smaller diameter tube onto a vacuum cleaner hose and suck the wee begger out through the main bulb hole or sumit?
cant even see it, poked around loads so i think best couse of action is take the lamp out and if i still cant see it turn the b*stard upside down and shake it
Ball***ks, not the cheapest thing to lose. Does the other side work, what do the PIAA LED sidelights look like next to xenons?
look smart but had to take the one out on the other side and put the regular ones back in til i get the little fecker back out :mad:
was all going smoothly til i put the second one in and it dropped out of mt fingers, ask 16v_matt he was there while i was swearing my head off
