Mk2 Owners - Identify This Throttle!
Folks, could anyone tell me if they have a (cable operated) throttle design similar to the following on their car?
I have something similar to this on my 1.2 but i'm looking for a larger example that can (hopefully) be modified to fit via a custom adapter.
If you have, could you name the car/engine type and (if possible) post some pics up or even meansurements (throttle butterfly diameter, PCD etc)
IIRC 1.6 16v could be likely or possible a phase 1 172?
Cheers!
  Lionel Richie
you have a 1.2 16v???
if so don't bother with a different TB, it won't work
you want the 2005 inlet manifold and plenham
No, its a DIET (1.2 8v).
I have a chap doing headwork on the cheap for me and i'm getting a cam. I've seen similar (but larger) throttles to mine before and am looking into fitting it via a custom adapter (Inlet is plastic anyway so should be easy to DIY).
Can't remember what i saw the similar one on...1.6 16v (K4M) rings a bell as does the phase 1 F4R.... :-S
Ah cheers.
Suppose if i was to be making an adapter a square throttle fitment wouldn't be a problem.
Can anyone supply me a picture of the ph1 172 throttle and maybe dimensions?
