Mk2 Ph2 Rear lights
  PH1 172
Bought these off ebay and replaced my boring mk2 ph1 rear lights.
I know others have done this also and I was wondering if their FOG LIGHT on the left hand side works or not?
Mine doesn't work and I can't remember if the mk2 ph1 rear lights even have a fog light on the left hand side as when I check the wiring (Pink wire to pin 4) I am not even getting a voltage unlike the one on the right where I am getting just short of 12v.
So does the mk2 ph2 left rear fog not work on the mk2 ph1 or have I got a problem?
I found the same when I fitted mine, I like things to be symetrical :eek: I just have the bulb in (even though it does nothing) I couldn't be fussed to wire it up.
  PH1 172
There's a guide on how to wire the other fog ya know ;)
Where is the guide matey?
TBH I would just make a junction point on the right hand cable and feed a supply from there to the left cable underneath the boot flooring...I just can't be bothered to do it either as I rarely use my fogs anyhow
