Mk2 springs on a Mk1?
Car  Mk1 Clio + Mk5 Jetta
Will mk2 springs and struts fit on a mk1? Also what springs and struts do people recommend for lowering around 35mm?
What litre is your car?
172 springs are the same as williams springs,
the 172 hub is wider where it meets the shock(so mk1 hubs will be no good or 172 shocks)(unless you use 172 hubs also)
Some fella fitted 172 shocks to his Williams with a couple of washers/spacers on clio16valver.co.uk...
