mk3 right steering wheel stalk fire!!! HELP!!!
  2x Clio mk3 1.5dci
Started my car earlier and smoke began to bellow out of the right steering wheel stalk with the wipers on. I disconnected the battery quickly and found that that the internal switch on the circuit board was all burnt around the "brights" on the circuit board. Should a fuse have blown prior? if so which one? It may be worth noting i have had some electrical issues prior as my lights went off i took fuses out one at a time on the fuse box next to the battery tried the lights and they now work even though a fuse hadnt blown. Since doing that my parking sensors dont work and when starting the car i now have to push my clutch and start as the brake and start says put it in neutral even though it is. Anyone have any ideas?
