If it's a front starter block there's a small torx bolt plug to take out and then you can stick a 6.5mm drill bit in the crank iirc
Just be careful because sometimes it feels like it's locked but you can miss the peg slot by a few mm and you can end up shearing the pin or gouging into the crank
