Morning start up
Car  from Trophy 2 work van :(
Does anybody experience weird goings on when you start up and drive in the morning??
It is almost as if I have left the speed limiter on, only for about the first mile until she has warmed up! I don't go above 3000rpm until it has warmed up but it speeds up and slows down by itself ever so slightly! Anyone got the same problem?
Very well documented cold-start problem mate. Have a search in the forum. Its very very common.
Thats fair enough but when you nearly get rear ended by a 7 1/2 ton lorry in the process it slightly pisses you off!!!!
It should only do it for around a minute to be fair.
If it's taking at least a mile to clear then you may have a problem.
