RB 182
I've hit a bit of a problem.
At the moment, my car is decat so would fail the usual emissions on an MOT.
I have the cat, but for some reason, it is way too small to fit in the gap that would normally fit the cat (if that makes sense), so something is missing!
I found a garage that would do my MOT with the cat OFF (personal friend) and find a way to pass it..
BUT, i've hit a rather large problem. My car doesn't fit on the MOT ramp.. it's too low.
The combination of 40mm apex springs and 15" PH1 OZ F1's + splitter make it bottom out at the front on the RR and the jack wont fit under the front when on the ramp!
So quite simply, i've got a place where i can get it MOT'd, but it'll fail.. or a place where it'll pass but i can't get it MOT'd!!!!
SO, i need some 16" wheels to stick on the front, a cat or some taller springs. And to make it worse, all the garages are now closed until the MOT is due! (3rd Jan) :dapprove:
I just thought i'd share my problem, as i'm hoping someone may have some advice for me or may even be able to lend a hand.
If it helps.. i'm down in the Grantham/Nottingham area from the 29th-1st of January to see some friends for new year, then back at work on the 2nd back up in Scarborough.
Any advice or help would be massively appreciated.. as the personal friend was my last resort really, so i've hit a horrible dead end!
...oh, and try not to laugh at my misfortune too much, ha.
Siddle
Siddle
