MOT time littles heads up please
Car  CLIO PH1 172
so its time for the cars first MOT (since iv owned it)
its a ph1 172 just wandering is there anything its likely to fail on iv obviously done all the usual checks bulbs tyres ect..... but is there anything these cars usually fail/get advisories on???
the car seems fine to drive apart from i sticky TB every now and then just wundering is there any last minute checks on anything i should do???
thanks
Check your brake pads are plentiful and the disks aren't pitted.
Make sure your handbrake is tight enough. I think it's meant to be 3 clicks to secure the car?
Got any cracks / stone chips in the windscreen? You might need to fix / replace it.
Do all the seat belts work and are they properly secured?
Condition of spare wheel?
Bulbs the correct colour?
Exhaust blowing / CAT present?
Also get the CAT nice and hot before the test - apparently it's more likely to pass on emissions if it's hot.
mot place is about 30mins down the motorway anyway so it should be nice and warm, i do have a small stone chip in the windscreen over my the passenger a pillar :/ other than that the rest shoul all be ok cheers
