does any1 know where i can get a dogbone mount for my valver?any links or anything? i want to order 1 now! andyspares which 1 is it?there is so many listed?
If its the lower mount your on about...they are just under £40.00 from Renault !! & the side mounts are about £60.00 each ! if you can get a toughened one...then go for it, but i would think youll get a bit more vibration feed back dueto the stronger rubber !!
there is the gearbox mount under the battery track, which supports the weight of the box. Then there is the dogbone, which isnt really a mount per se, but stops lateral movement.
So, im guessing its the rear one since the dogbone is at the rear.....
