mount
does any1 know where i can get a dogbone mount for my valver?any links or anything? i want to order 1 now!:@ andyspares which 1 is it?there is so many listed?
any help will be great:)
I wouldnt mind knowing this as well, and how much?
Also (sorry for hi-jacking your post) does anyone know how much the strengthen ones are from Hill Power?
If its the lower mount your on about...they are just under £40.00 from Renault !! & the side mounts are about £60.00 each ! if you can get a toughened one...then go for it, but i would think youll get a bit more vibration feed back dueto the stronger rubber !!
??? that has confused me now ???
I thought there was only one gearbox mount but according to that there are two! (front & rear)
Might be worth getting both then
there is the gearbox mount under the battery track, which supports the weight of the box. Then there is the dogbone, which isnt really a mount per se, but stops lateral movement.
So, im guessing its the rear one since the dogbone is at the rear.....
