Clio 2 Sport
I have a Clio 2 Sport 182 body with a Clio 3 Sport 197 engine.
For 4 years it's been running without any issues. It has the 182's ECU which is managed by a Unichip Q. It has the 182's throttle body aswell.
When i drive at low rpm, usually nothing bad happens, but when i go over 5000 and keep going then it intermittently goes into limp mode which will eventually break something because of the shock of the engine stopping suddenly at high rpm's between 6000 and 7000 and i really don't want that to happen.
I replaced the throttle potentiometer at the throttle pedal, got different O2 sensors, cleaned all the sensors, replaced the little traction control box, cleared the memory of all errors, reset the ECU by disconnecting battery and by using diagnostics machine, i have checked the wiring as far as i could and found a few areas that were damaged and fixed it.
I am saving money to replace the throttle body seeing that the 182 parts have 150 000km on them and the newer engine has 40 000km, is it worth getting a new throttle body? Hard to find used parts here in South Africa as this particular Clio is very rare here, so if anyone could help me get my hands on a part that can be shipped, that would be cool.
Please help, I miss the car i used to drive so confidently.
