My clutch dissapeared??????
  My bicycle!!
Right earlier i changed from 3rd into 4th, well i was going to but as i pressed the clutch pedal, it went straight to the floor as if the cable had snapped, so i pulled over as you to have a little look! pooped the bonnet, clutch cable fine?
i was confused, got back in my car, pressed the clutch and it was ok again? only biting point basicly on the floor?
Then whilst driving it again, the clutch pedal moved then the biting point was way up high?
Any ideas? cheers :)
Check the teeth on the adjuster I'd bet there broken.
Or else the clutch springs are going.
Or the clutch cbale if its not Renault get a Renault one fitted and regardless make sure it routed correctly.
