Right, before everyone starts slating for running valver managment, i wanted to do it a) to see if it would run, B) to try and escape the dreaded immobiliser issue.
Anyway:
My nemesis, the F7P engine:
The bottom end started knocking like a wood pecker on speed on sunday night, so, couldnt source a engine cheap enopugh so the 172 conversion is going ahead.
Monday:
Not much done, 172 engine reassembled(sump and b/e) and all bracketory stripped off leaving just the bare block and head.
Tuesday:
Made a start on the valver, Wiring loom disconnected, bastarding downpipe nuts were siezed so it had to come out the bottom. Subframe off, exhaust off, linkage off, Ball joints disconnected, driveshafts off, then dropped the engine out.
Wednesday:
Got the 172 engine in and on the mounts for luke(Schnakey) to fabricate the exhaust downpipe/decat etc etc, as on the valver the manifold and downpipe run under the subframe, whereas the 172 it runs between the bulkead and the subframe.
The original downpipe and cat setup:
The mock up:
The half finished, ready to do the mock up and trial fit/modify of decat
Plenty of room! :|
While luke was fiddling about with that, i was getting on with getting the engine on the mounts, subframe on, and the wiring loom. I have decided for ease of the conversion as its on a very short deadline to run a dizzy and use the valver managment and get it remapped to suit the 172.
Upon getting it on the mounts, i discovered how much of a problem this was going to be...
Slapped the inlet on and put the bonnet on to check clearence(if any :lol: )
Arse:
Thursday:
Subframe back on. And another problem, the way we welded the downpipe/decat meant it was constantly hitting the subframe, so we modified the rear mount brtaket to hold the engine at a very slight angle more than it would, and this solved the problem.
Not much, but enough clearance for the engine movement
Decat welded up, with lambda flange included!
My dizzy adapter plate, courtesy of PanTec engineering!
Friday:
I tiedied up the wiring loom, moved a few sensors over from the valver lump to enable all the incar oil guages to work, and adapted the loom to suit!
I also fitted a Air/fuel ratio meter to monitor the engines running!
Ive also made up a braket for the alternator.
Saturday:
Discovered yet another niggly problem...
The deact we welded up doesnt drop down enough from the body, so when trying to connect the mid section, it hits the heatshields under the gearstick!so after swearing, and the well known stage of looking, staring, poking, and walking away, we started the jiggery npokery of the decat.
Thats all the prgress made so far, not bad for a weeks work IMO!
I was hoping to have it running yesterday, but due to Renault not stock any gaskets, it will be atleast tuesday! but it gives me more time to play about with coolant hoses, and the HT leads ive goto make to fit a dizzy.
List of stuff left to do:
- Coolant hoses
- Finish exhaust (lukes job)
- Refit driveshafts
- All liquids
- Find an airfilter to fit!!
- modify bonnet framework to fit around the engine
- Fit check straps on subframe
- Fit inlet manifolds and gaskets
- Fit and modify fuel rail and Fuel lines
- get a 880mm aux belt
AFAIR thats all that needs doing...
And to set up the timing. all can be done in about a day me thinks, But, ive got all day today and tomorrow to get those done before i can fit gaskets and manifolds. I had it cranking last night, so the wiring appears to still be good!
Today (Sunday)
Not much prgress today, mainly due to lack of motivation due to tiredness!!
But what got done:
Oil and gearbox oil in
Driveshafts
Bottom ball joints
Trackrods
Passenger wheel on
Subframe check straps
Great progress today, after further modifications to the exhaust, it seems to fit...all bar the lambda, but thats not a problem!!
Today, I got the inlet fitted, plugs and leads, fuel rail, both wheels on, wiring loom further tied up, and started doing the igintion timing, shes coughing and spluttering, but due to the cam timing its going to take alot to get her going, but its so close! she WILL be running tomorrow!
Only thing left to do now, if Fine tune ignition, and sort out coolant hose and fan wiring!
Right, been having a small hink about this, its stalling if it gets anything above 4krpm. sounds like fuel starvation, but theres plenty of fuel. god knows.
So options:
1)Try and find a 2.0 williams ecu to see if that helps?
or
2)Engine out to change the flywheel, dash out and redo it all and run it on 172 managment.
Problems:
1)
Finding a williams ecu.
2)
Transponder immobiliser... Due to renault being ghey and wiring the decoder ring through the UCH which controls every fricking switch or light in the whole car means its a bit harder.
Ive traced the wire from the decoder ring to the UCH, need to find where it comes out of the ecu now. But will it work with out the uch? i dont know and frankly its very annoying and frustrating why it wont work. just want to sit and cry lol.
Right, ive had an hours sleep and tbh i feel like crap! but, i have i think concquered the 172 immobiliser issue, ive cut out the uch and joined the wire where it would be the oither side of the uch. just now need to pull the engine out and change the flywheel over, fit the 172 clutch, and work out what pins do what on the valver side of the loom
Right.
Still no further with the car side of things due to other jobs and lack of motivation as im not getting paid for it! lol but, the wiring loom is on my dining room table(thank fook the 'rents are away!) and ive pin'd up the wires i NEED from the bulkhead on the 172 loom and the wires into the ecu. now today or tomorrow im taking the engine out and fitting the 172 fly, clutch, etc etc. then refit it all and start again
Well slight set back, the engine is out, 172 flywheel is on, but the bolts for the clutch are different to the ones on the valver, now ive got the bolts somewhere, just need to find them! need my car ready by saturday, as ive got a trackday sunday!!
And thats my progress so far, my ecu is at RS Tuning having the immobiliser removed, should be back today fingers crossed, the car is now on the ground, on its wheels waiting patiently!!
Anyway:
Monday:
Tuesday:
Wednesday:
The mock up:
Plenty of room! :|
Arse:
Thursday:
Friday:
Saturday:
- Coolant hoses
- Refit driveshafts
- All liquids
Today (Sunday)
But what got done:
Driveshafts
Bottom ball joints
Trackrods
Passenger wheel on
So options:
or
Problems:
1)
2)
Right.
