my exhaust gas monitor warning light is on...
What else would you like to know you havn't been very detailed, I mean is it running rough or anything abnormal about the car?
If it came on for no reason perhaps a lambda is faulty.
  none :(
i started it up and its just stayed on, gonna ring rac in a min to see if they can come out.
wouldnt mind only had it 2 days lol#
if its the lamba, will it need to go to renault and how much roughly will it cost, is it still safe to drive, it drives as normal
  BMW M135i
Yes the RAC will be able to reset it, anyone with an OBDII reader will be able to. Has had this a few times with his, ended up being a dead lambda sensor when we viewed all the sensord data.
In response to your other question if its running fine (ei No missfiring then you can drive it fine) I'm assuming you dont have a decat?
