my first night pics
  black ph2 172
here are a few pics from last night, comments and critacisma welcome, how could i improve light trails and get them a little more focused, i used a nikon d60 with standard 18-55 lens
A lower aperture will get more of the lights in focus.
What f number did you have it on? I used f16 when I did mine I think and that seemed to work but im not expert..
Ian
  Focus TDCi
Not having tried them myself I'd imagine it would very much be down to the traffic flow? If there's all sorts of cars going past, the light will not be in exactly the same place causing the trails to look a bit indistinct. From other photos I've seen it also seems to depend on the amount of additional light sources affecting the scene.
Having said all that; as Revels says, using a narrow aperture will probably reduce the glare and keep it more focused.
  black ph2 172
thanks guys i had the f on f5.6 and also tryed f11 but didnt see much difference, i had my shutter speed on about 20 seconds and iso on 100, ill just have to keep tryin:D
Ian
  Focus TDCi
Aye it's the best way :)
It's always a bit of a balancing act, as by using a narrower aperture, you may find that the shot is underexposed, so you might end up with the red and white lights and the rest of the photo without any detail. So then you'd have to raise the ISO, which would increase the noise. It's finding the settings that produce a photo you like that's the hard part!
If you look at the first two photos in post 9 of this thread: http://www.cliosport.net/forum/showthread.php?t=387230
they were taken with the settings:
25 seconds
f/7
ISO 100
44mm
and
15 seconds
f/4
ISO 100
28mm
which is what makes me think it is partly down to location and traffic flow. I'm not sure what setting you had for white balance, but they look maybe a bit yellowy? Other than that I do like them though :)
  black ph2 172
thanks for your comments, ill keep practicing, might enrole on a course as only had my camers since christmas. (IAN) i had the white balance on auto as not figured what to do with that yet lol.
