My new printers taking years to print out
Well not actually years, but a long time between each job:dapprove:
Say if I want to print out a few car ad's (as I have been) it's taking ages between each one, the print queue had about five in it just now (I have deleted each job once the copy has come out as it said not all of it was done, but it was)
What's going on ??
Printers a canon ip4500 which i've had since saturday.
  330Ci (Fail)Sport
Don't know the exact printer, but maybe turn down the level of quality a bit?
If you don't want to go any lower, try reducing the amount of ink used per print, I find on most printers that even turning it to the lowest, the print is great. No loss in quality, just less ink on the page so quicker to print and quicker to dry. Which is another option to turn down: drying time. Its to make sure the next page doesn't smdge the one just printed, but on lower ink, you shouldn't find any smudging anyway.
  Scirocco GT 2.0
How have you set the printer to spool?
Start printing after last page is spooled? or Start printing immediately?
or is it printing directly to the printer?
MRBILLYUK
  FF Jeden Osiem Dwa
Should have got a decent printer like an Epson . I'm sure somebody did recommend them :quiet:
Not a clue:eek: I hooked it all up & then started printing (i've done the head alignment shizz & all that)
I was told that epson were crap & given reasons.
This one came out top by some pc mag, if it's good enough for them it's good enough for me. I was told by a few that canon are good.
  Scirocco GT 2.0
Right click on the printer and click Properties then the Advanced tab and make sure the spool is set to "start printing immediately"
That one has the dot in it & so does spool print documents....
Is that right ? Or do I need to remove the spool docs one ?
  Scirocco GT 2.0
They both should be selected, sounds like that isn't causing the problem, so that's one off the list..
How is the printer connected? do you know if it is USB 2.0?
  Scirocco GT 2.0
:S not sure what else it could be then tbh, try selecting "print directly to the printer" in the printer properties>advanced..
