my pc won't recognise the scanner any more - help !
cat171
My scanner (a HP 4100c -old:eek: ) won't work with the pc despite me downloading the relevant drivers for it etc.
When we got this pc (about 3 years ago) it didn't work with the scanner so I d/loaded the drivers etc for it (i have the disc but the scanner is old, so doesn't work on xp, I had to say I was on windows 2000 before)
I'v just done that again from the hp site (my bro got a virus on the pc a while, back so we had to start over again)
now it won't work - what else can I do?
all of the software & drivers are on the pc - i've even plugged the scanner back in again, but to no avail :rolleyes:
cat171
I can't even see the scanner on the list- any one any ideas what it ought to say ?? (i guess it should just have the name on the scanner ?)
JonnyK
Honorary Member
  500 Bhp Golf R 7.5
im guessing you have ran the add new hardware wizard?
cat171
I ran the ad new hardward wizard & it said if you have disc for it etc, put it in, I have a disc but its doesn't work:rolleyes: (the scanner don't work on xp) I had to instal a driver as if I was using windows 2000.
I'm really lost with this now !:S
It worked fine before (i managed to install the drivers etc & did the same just now, but no luck !)
I can't see whats goin on, I have pulled the lead out of the scanner & put it back in, the pc then says unrecognised usb port !!:mad:
try another usb port, if it doesnt recognise that particular port?
you sure you have got the latest drivers off the net?
JonnyK
Honorary Member
  500 Bhp Golf R 7.5
you could try getting the lastest xp driver from the manufacturer's website?
