my temperature gauge dont move on my dash.
Have you had the dash off?
More likly the temp sensor wiring has come loose. If you open the bonnet remove the engine cover and the 4 pipes you see curling round to the engine on the right hand side of these you'll see a sensor with the wiring which should be plugged into the snesor facing forwards. Check that the wiring is plugged in.
Either that or you will start doing 12mpg like my old 182 did(if the sensors gone)
ian
