My washing/detailing.. Is this right? +Questions!
Okay as title, is this the correct way to wash/detail?
Also a few questions at the bottom!
Pretty new to this so hopefully I'm right and learnt from reading off here and other detailing forums!
So here's how I would wash/detail in order.
1. Jet wash: loosen up the dirt, wheels etc.
2. Wheels: iron X.
3. Snow Foam: remove more loosened up dirt including wheels with wheel brush & using a detailing brush for inbetween badges etc.
4: Iron X car, Bug shifter, Tar remover
6. Clay: using clay lube etc.
7. Wash: remove all dirt etc from car with wash mitt including wheels using quality shampoo.
-Dry with microfibre towel-
8. Glaze: black hole (BG182) buff off.
9. Sealant: poorboys EX-P, leave for 30 mins. Buff off.
10. Wax: chemical guys wet butter wax, panel at a time, buff off.
11. Wheels: protectant wheel sealant.
12. Hydr02: quick "wax on wax off" mist of this to add water resistant effect to paint.
Questions:
1: I've read a process like all of the above is a once maybe twice a year thing to do..
Where do I pick up from again after the car gets dirty? as I can't repeat this whole process every other week.
Would it just be:
Wash, rinse, glaze, sealant, wax, hydro?
2: with a black car, it gets dirty or at least shows imperfections every 24 hours.
I have a few quick detailers, do I water down the car first to loosen up dust/dirt then use? Dust mitt all the crud off then use? Or simply use to clean?
3: How long does the process last for? I've done all of the above for then it to heavily rain 3 days later and then the aftermath to look like I've been off-roading all weekend when In reality it was just parked up.
Is the wax/glaze etc still underneath the dirt or has it all rained away?
Same again with a jet wash, if I jet wash said dirt off, will that also blast away all the glaze,sealant and wax I've put many man hours into putting there or?
Thanks for any help!
I realise this is probably just another noob with the same questions with the same thread over and over but I'd like to think I'm 80-90% there with knowing what to do. Just a few unsure questions needing answers and verification of my process! :)
  Golf 7.5R & Clio 200
Your wash and decon process are the wrong way round. Im off out now, but zim sure someone will re-order and give you a few pointers. If not I'll have another butch when Im back.
Knuckles
ClioSport Admin
I've jumbled your process up a bit to show you how I do it
. Wash
4: Wheels and car: Bug shifter, Tar remover
.rinse
4: Wheels and car:iron x
.wash
7. Rinse/ mist with a quick detailer as a drying aid
*if you've touched the car, I.e. Used clay, I'd recommend even a mild polish to remove any marring you've caused*
12. Hydr02: quick "wax on wax off" mist of this to add water resistant effect to paint. *this is unnecessary tbh if you've sealed, but it doesn't hurt anything
Questions:
Yup, after a 'big clean' you just keep on top of it with maintenance washes
Contactless/minimum contact washes; snow foam, citrus pre wash etc, jet wash and quick detailer
Would it just be:
No glaze or LSP, try not to touch the car.
Snow foam/citrus pre wash, then rinse, it should r ove most of the crap, then qd/spray LSP to protect if need be
It's a piece of string question really, it all depends on your prep and lsp
If it's a decent LSP, then it'll be under the dirt.
At CSS this year, my car got filthy, but because I did a decontamination and protection, when it rained very heavily, it cleaned my car :smiley:
Nope :smile: as long as you don't have it set silly powerful
Any more questions, don't hesitate to ask, everybody needs help at one point or another[/QUOTE]
