Mydylan spacers with camber
Maybe 5mm or 10 picking my turini from the paint shop next week so was gonna do together. But unsure if need bigger bolts etc
Just read pms do 5 mm spacers so dunno
Once on you will have a better idea on size. Mine looks better with 5mm spacers but drives better without. My wheels are 38 for referance
Rear camber shims he's on about.
You might not need longer bolts, but the ones currently in there won't come out without a fight usually. So you may need replacements anyway.
Ye sorry sorry rears but fronts on payday too
These
Thanks both :) will order when I home. We're do this fit? Take rear discs off then... and is camber a good idea looks good but don't want problemo lol
Better to turn the nut on the rear whilst just holding the torx on the front, rather than just trying to turn the torx head when removing the bolts as the head can strip. The originals can be reused but probably better to buy the new set.
Take the rear disc off (remember to take not on which way the washer behind the disc goes)
Remove the 4 rusted bolts out. May need a grinder as they'll more than likely be seized and they are torx style bolts.
Once removed the hub will be loose so you can fit the new spacers amd replace with the new bolts.
Disc washer and disc back on and hub nut done up to 175nm.
