You just need to go to tools > profiles, then choose which profile you want it for, then go options > personalise, then scroll down to message alert tone, then click your select button (middle of the joypad thing) or got options > change. Then just scroll down to the mp3 you want..
As above, they certainly should show up - are they stored on your phone memory or the memory card - it will pick them up from both but sometimes mine would 'forget' it had a memory card inserted & I'd need to remove & re-insert it.
don't know then sorry, should just work in theory. Only thing I can suggest is to try them on the phone rather than the card even though it shouldn't matter.
Maybe the phone has a bug and needs a factory reset?
