Need a replacement rear brake light, are they easy to change?
ant
  yep.
open boot and there should be a 3 pronged plastic nut type thing behind where the rear lenses are. just undo them and pull the light lense off the car. all the bulbs are sat on a board which is just held on the lense with 4 clips, just prise it off and change the bulb.
thats an 02 172 btw!
Fletcher
Cheers Daze went a found the instruction manual, and have successfully changed the old bulb:D
