NEED ADVICE PLEASE!!
Car  clio mk1 ph3
Hi, i have a mk1 clio ph3 biarritz its a 1.2 16v and i want to do a 2.0ltr williams engine conversion and need to know the following things please...
1, Can the conversion be carried out on this ph3 model?
2, The central locking activates an imobeliser...will the conversion affect this?
3, Does the scoop from the williams bonnet need to be there, to clear the inlet manifold?
4, Will the williams rear disc brakes fit on this ph3 model?
5, Are there any other flaws i should know about?
The conversion is not being done yet....just an idea for the moment.
Thanks for your help. Josh.
1. yes
2. no the immobiliser is in the ecu, williams' dont have immobilisers in the ecu.
3.yes the inlet manifold hits the bonnet otherwise
4. yes if you get the complete rear beam
5. replace your fuel pump and lines. and exhaust. and make sure you get a heatshiled for the brake lines.
Also my ph3 does not have to wider arches the williams has....will the full rear beam be wider aswel?....and possibley not fit?
Cheers. Josh
