Need Advice!!!
Car  NEED V6!
Just bought another clio 182 in yellow and with the cup suspension pack, but after driving 500miles or so, i've noticed that the suspension is softer than my last car, surely the renault garage have'nt just stuck cup wheels on the statard 182 and called it a cup cause if they have there will be trouble:evil: , how could you tell from a 182 with cup suspension or without what should i look out for.
thank's
The bolt spacing on the suspension is different between Cupped and non cupped but i can't remember the measurements off hand... i'm sure someone will post it up soon
Ride height wise its only 5mm difference so you'd be hard pushed to tell visually
there should be something in the chasis number which will tell you if its cupped or not. iirc...
eddes the person to ask...
Could Renault UK cust services confirm their records from when it entered the UK ?
yeah they should be able... tis about the only thing they have ever been usuful for in the past. confirm if its a uk car and also the spec.
