Need help Sun roof leaking
Alryt iv jst been looking through lots of posts about the sunroof leaking on a 2001 mk2, but none that say what to do exactly.
i need to know what to do my sunroof in leaking but it is not leaking through the actual sunroof it is leaking through the roof just above the sun visor.:S
cheers chris
Chances are it'll be leaking where the interior light/alarm sensors are.
You need to try tightening the roof aeriel (you will see a bolt when you remove the interior light etc) Give the screw a bit of a tighten up & see if that works.
If that doesn't sort it your probably going to have to try some sealant (if you do, unscrew the base of the aeriel outside the car, put the sealant round & re-tighten it)
Hope that helps.
