Need Some Rubber...
Car  Coiley'd Clio PH2
Afer being advised by the authorities about a month ago that i should replace my rear tyres i have decided that i should probably order some now!
I currently have Toyo Proxes 195/45/R16 on the front and back. Very good tyre in the dry, but not so good in the wet.
Anyone recommend any others?
Also, i would quite like to get some 205 width tyres, this should be ok right? Its lowered a fair old bit, is it likely to scrub the side of the arch?
Wouldnt mind a lower profile aswell, but obviously this will put my speedo out a bit more!
Nick
mines is lowered 40mm withh 205 tyres and it rubs so yours will defo rub imo. i have pe2's and i cant fault them tbh but a bit expensive.
