My computer "Steve-PC" which acts as a server and runs Vista Ultimate is causing problems.
The other two computers in the network (one running XP Pro the other Vista Ultimate ) can access \\Steve-PC\artwork but cannot access the listing of shares (\\Steve-PC). I get:
"\\Steve-PC is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions.
Access is denied."
If I right click > properties the computer I get
"You do not have the appropriate access rights for this server. For more infomation, contact your network administrator"
but as I said if I enter the UNC path to a share, it works. I just can't view the "listings".
I'm stumped, i've tried:
- Disabling firewalls
- Running the network wizard
- Disabling file and printer sharing, then re-enabling it.
- Switching off all computers and router for a few minutes before switching back on
- Changing the workgroup (on all computers)
- Changing the security in safe mode
- Enabling the guest account
- Spyware scanning
And all the computers have the same accounts/passwords.
It's weird as it's not as if i'm being rejected access as full UNC paths work, but it thinks I dont have permission to view the index.
Any suggestions? Incidentally everything seemed to be working perfectly until about 5 days ago, so it's probably not a hardware or driver issue either.
Thanks!
Access is denied."
- Spyware scanning
Thanks!
