New 360 Tech Article
Hmm, from the article:
Around back you get an optical audio out, Xbox 360 AV connector, HDMI output, three more USB ports, Ethernet port and input for Microsoft’s Kinect peripheral due out later this year.
Interesting, I've not looked into it, but does this mean that you'll need a Slim Xbox if you want a Kinect?
edit: I also notice that they now have an optical out on th ebox itselef, no more need to buy the extra adaptor/hack up one if you want HDMI and optical out.
How do you go about transferring your data of your current HDD onto the new one, will a normal transfer kit sort it?
Yes, a normal transfer kit will work, no probs.
The slim comes with the Kinect port that will power the Kinect hardware.
If you have an old xbox, you will need to plug the Kinect hardware into a power socket.
Will probably get this when it comes out, will see how much it works out for a trade in with my Elite.
The Slim's are £199 on Amazon an present.
Ahh, thats OK then. Thought it'd be a bit cheeky for them to require a new slim xbox.
