New Clio F1 owner needing general advice
  Clio F1
Evening all,
after always wanting one of these after reading/ watching endless reviews I took the plunge one evening (much to my Mrs despair).
I’ve bought a low mileage example that’s a little rough around the edges. My plans to keep it and use it as a weekend car. I want to return it as close as possible to standard (Boring I know) but it will be regularly used.
Ive used this forum to read Up on advice (thanks, people do read it!) and have just sent off my steering wheel to Royal.
I’m struggling to find a couple of things so could do with any steer:
  • New gear knob- like I mentioned original style if possible, plenty on eBay for a tenner but is there a better quality option anyone would recommend?
  • black door pillar strips- (probably have a name)- mine are starting to peel away so need them replacing. can anyone recommend a replacement? This has previously been done in a carbon fibre effect, is this original? Also the spoiler has been wrapped in the same- was this originally just painted?
  • F1 floor mats- were these different? I’ve seen the OEM mats with yellow trim if not.
  • F1 decals- the car I bought was red, I’m getting it machine polished soon and ceramic coated would you recommend removing the decals then re applying new ones or leaving originals?
cheers in advance, I’m new to this but looking forward to getting stuck in and enjoying the car.
I’ll post pictures of before and after when it’s done.
Clio_fool
Carbon wrap isn't oe, the B pillar wrap was originally a pain to remove so be thankful for that but replace it with matte black ones off ebay. If the origin f1 decals are in good condition keep them, copies are scrap and they cost far too much from Renault to replace if they aren't falling off.
Martin_172
There was an optional extra aluminium gear knob from Renault, it was well over £100 from memory but was also used as standard on the Laguna GT, shift feels much nicer with it, that's what i run
As above with the decals keep the originals if possible.
From memory they didn't come with mats so it was what ever the original dealer/customer specced, some will have had the renaultsport accessory mats, mine had the normal mats which i think were called expression or comfort mats
  Clio F1
Hi all,
cars coming on really well. I’ll post some pictures when it’s done (and I stop spending all my money on it!)
Im currently having the brakes done, the rear calliper is stuck on and needs replacing. they are red all round and I thought were Brembo on the F1 is this the case?
  Clio F1
I all, really appreciate all the advice. My cars nearly done and I couldn’t be more pleased with it. The problem is the closer I get to finishing the more perfect I want it (will be a never ending one)
does anyone know where to source the replacement keyless door handles- part number 7701478162
cheers again for the help
  Clio F1
Hi all,
My cars coming on really well, I’m really pleased with it, absolute money pits when you start but I’m determined to get it as high of a standard/original as I can.
cheers for everyone’s advice it has really helped.
There’s a couple more bits I wanted your advice on.
  • The central display screen- it only half works, a common fault I’ve heard caused by the sun. The top line works but the lower one doesnt although has come on intermittently. Looking on EBay it’s a common one- serial number is 8200307274C. Seem to be going for mega money! Is there anyone/anyway to have them repaired?
  • the door handles- part number is 7701478162 I think.anyone know where to get them? Or is it easier to just respray?
I’ll post more pictures when done but if you see anything not right or that looks shite let me know.
  Clio F1
Hi all,
Complete long shot but worth a try.
I've got lacquer peel on my front bumper (Red cars ! 😖) so looks like I may need my front bumper spraying. If I do I've been told I'll have to replace the sticker.
Does anyone know if the originals are still available and if not (most likely) who does the best replacements?
I've tried to keep the originals and don't fancy the ebay jobs.
As always, Cheers for the advice
