Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Throttle bodies arn't worth it unless your a 2.0 btoom end and cams and either a ported head or a 2.0 head at worse.
2.0 Bottom end with a ported head and cams with the stock manifold and a remap ae the best idea IMO. SHould get you around 180hp.
Cost
Head work £550
Cams err expensive for the AWT special which make the best power/ power range. I think your looking £650 with the bits you need.
Remap £300
2.0 bottom end £400 LTR do 2.0 bottom end transplants for £750. Probably another £400 to fit the cams etc.
Brkaes on the 2.0 are the same as you car but you do have upgrade options.
4 pots which I'd recomend personally as there nothing like them . Or harder pads.
