Meg'd r27
I can do nothing but laugh to be honest at the moment its just not going my way.
The new engine is in, fixed the climbing revs... was a bad connection in the brake vacuum hose so at least thats one thing.
So the new issues i'm having now are:
-Coolant is just going walkies, no puddles no leaks as far as I can see. so i'll probably get the system pressure tested as the next port of call. Any other suggestions where it might be going?
- Can't get reverse at the moment, and first is where reverse normally is. I'm presuming that the gear selector arm just needs rotated a bit, clockwise a little bit I guess.
- Strange noise coming from the gearbox at idle which goes away with the slightest of touches of the clutch, also seemed to go away after a short drive there but due to the next problem I wont know if it comes back when its cold again. Sounded almost like a mix between a tweet noise and running your fingernails down a blackboard lightly!
-On the first test drive there the engine sounds very ticky, more so that the old one ever did. I gave it some accelerator and revved fine but then started to misfire a bit. Plugs, leads,coilpack and lambdas were fine on the old engine before it went so I would have thought they would be fine.
Driving along it randomly just cut out and when trying to start it back up it sounded like the a motor was just spinning and not trying to catch at all. Same noise as when the valve went on the last engine :S
Any ideas where to start on that one?
- I havn't the carbon canister wired back up and is throwing a code up, possibly what is causing the engine management light but it wouldnt cause any running problems would it??
No doubt some more problems to come across before I get back on the road ffs.
Ready to give up and punt it on tbh... losing interest by the day :dead:
