The latest offering from Auto Finesse - Dressle.
We're excited to reveal the latest product to the range, Dressle, the versatile all purpose dressing for exterior and interior trim. This water based dry cure dressing is the finishing touch for a multitude of areas all around a vehicle, from engine bays to interiors, wheel wells to intricate grills, adding a new look satin sheen and UV protection in one step...
Have you ever struggled to dress modern honeycomb grills, or wanted to add that finishing touch to a freshly detailed engine bay? Then Dressle is for you! This liquid, dry touch water based dressing can be sprayed directly on to the surface or applied via an applicator or cloth depending on the area of the vehicle you are working on and your personal preference. This highly versatile dressing is also great for dressing hard to reach areas such as wheel wells and engine bays, due to its spray on and walk away nature, simply dose the surface with a few fine mists of Dressle and leave to cure.
Dressle is also a great product to enhance the appearance of the cockpit of your vehicle, as it drys to a non greasy finish, it leaves a pleasant and natural sheen. The UV inhibitors help prevent interior surfaces from fading, and keeps a deep rich finish to your interior plastic and vinyl trim, it contains no waxes, oils, or petroleum distillates.
Dressle on interiors:
To get the best from Dressle on the interior of your vehicle the best method of application is to apply a few spritz of product to a microfiber work towel and spread evenly across the dash, door cards and other plastic areas you wish to coat. For intricate parts such as vents and grills a top tip is to apply a small amount to a detailing brush and apply via brushing it on to the surface. Wipe away any unwanted excess and thats it!
Dressle in the engine bay:
Nothing beats a nice clean engine bay and Dressle can take that one step further, after a thorough engine compartment detail allow the engine bay to dry then spray Dressle liberally to all surfaces, close up and get on with some other detailing tasks while it cures and dries. Pop back after an hour or two and mop up any remaining dressing and thats it, its that simple...
Dressle on those tricky bits:
Dressle is useful for all kinds of plastic trim, moldings, plastic & vinyl parts around your vehicle, from dressing those tricky Honeycomb grills, to preserving and protecting rubber door seals to wheel arch liners and more...
The finished results:
Dressle also works wonders on rubber door seals, helping preserve them whilst restoring a new look natural finish, it also prevents them freezing closed in the colder winter months.
Being water based also means any overspray of excess product can easily and effectively be cleaned up simply by using detail spray...
Thanks for taking the time to read, if you have any questions or comments please feel free to post.
- More info at: http://www.autofinesse.co.uk/new-dressle-all-purpose-dressing/
