New head
CJ
Car  Blue ph1 172
One of the spark plugs has threaded on my ph1 172, trying to find someone in swansea to fit a helicoil is a nightmare. How much do you think a new or 2nd hand head would cost as it may be easier just to replace this. thanks.
ring nick hill (01530 273633) he may have some spare heads laying about or matt on 01254 386661 may have a head or two in the warehouse
is the head already off? if it is you could try tapping the thread depending on how bad it is. this worked on my mates punto after he put a plug in at about 45 degrees to the plug hole!!
Danlp6 said:
PM stan* he's in swansea, and a very good mechanic.
LOL, he'll be upset you've called him that!!!
he's a precision engineer/engine builder/specialist/encyclopedia/know it all
etc etc!
A good tip when your puttin in new plugs is to use a piece of 10mm plastic tubing on the end of the plug to start it on the threads , don't use the plug socket straight away . Then if you do cross thread it it spins on the end of the plug and won't let you screw it in , if it does go on the thread nice n bonny then you use the plug socket to tighten it up . Thats how i always did it on my pug 306 , works everytime .
etc etc!
lol damn f**king right, i aint no grease monkey :) !!!
anyway...
give Huxtables a call on 01792812165 ask for Charles
Im from way up north (Carlisle), but moved to Swansea 4 years ago to do my degree....missus is from round here, so decided to set-up-shop here for the next year, then move back up home (avec her) when business is on its feet
