New owner looking for history...
  Clio 182
Hi guys! Cracking forum, just looking for some background info on my clio I've recently taken ownership of.
She's a black gold 182 with recaros, registration WR05VNA
She's got cliosport.net stickers on the side skirts, unfortunately the person I had the car off had 'lost' all the service history. Just looking if anyone recognises this car
Thanks in advance!
Thanks in advance!
Registration number: WR05VNA
  • Vehicle make RENAULT
  • Vehicle model CLIO
  • Date first used 26 July 2005
  • Fuel type Petrol
  • Colour Black
MOT history of this vehicle
  • Test date 9 November 2016
  • Expiry date 8 November 2017
  • Test Result Pass
  • Odometer reading 94,049 miles
  • MOT test number 5440 9746 3972
  • Advisory notice item(s)
    Nearside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    Offside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    Nearside Rear Brake pad(s) wearing thin (3.5.1g)
    Offside Rear Brake pad(s) wearing thin (3.5.1g)
  • Test date 28 August 2015
  • Expiry date 12 September 2016
  • Test Result Pass
  • Odometer reading 86,715 miles
  • MOT test number 2898 5044 5207
    Oil leak
  • Test date 27 August 2015
  • Test Result Fail
  • Odometer reading 86,713 miles
  • MOT test number 8385 7953 5201
  • Reason(s) for failure
    Front brake disc in such a condition that it is seriously weakened (3.5.1i)
    Nearside Front Front constant velocity joint is insecure (2.5.C.1b)
    Nearside rear brake binding (3.7.B.1)
    Brakes imbalanced across an axle (3.7.B.5b)
    Exhaust emissions carbon monoxide content at idle excessive (7.3.D.4)
    Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
    Exhaust emissions hydrocarbon content after 2nd fast idle excessive (7.3.D.3)
    Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.3)
    Oil leak
  • Test date 11 September 2014
  • Expiry date 12 September 2015
  • Test Result Pass
  • Odometer reading 86,564 miles
  • MOT test number 1952 4485 4295
    Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    Items removed from driver's view prior to test
  • Test Result Fail
  • MOT test number 9794 0495 4256
    Nearside Outer Front Front constant velocity joint is insecure (2.5.C.1b)
  • Test date 13 September 2013
  • Expiry date 12 September 2014
  • Test Result Pass
  • Odometer reading 85,078 miles
  • MOT test number 9270 4615 3216
    Nearside Front constant velocity joint gaiter deteriorated, but preventing the ingress of dirt (2.5.C.1a)
  • Test date 7 August 2013
  • Test Result Fail
  • Odometer reading 84,936 miles
  • MOT test number 1699 8911 3265
    Rear passengers seat cannot be secured in the upright position. (6.2.A.2)
    Nearside Front Front constant velocity joint gaiter insecure to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
    Exhaust noisy (7.1.4)
    Centre Exhaust has a minor leak of exhaust gases (7.1.2)
    Engine covers fitted obscuring some components in the engine bay
    Under-trays fitted obscuring some underside components
  • Test date 6 August 2012
  • Expiry date 10 August 2013
  • Test Result Pass
  • Odometer reading 81,170 miles
  • MOT test number 4277 1981 2278
    Nearside Front Track rod end ball joint has slight play (2.2.B.1f)
  • Test Result Fail
  • MOT test number 3380 4951 2229
    Nearside Front Lower Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
    Rear Exhaust has a major leak of exhaust gases (7.1.2)
    Rear Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
    Front Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.5b)
  • Test date 6 August 2011
  • Expiry date 10 August 2012
  • Test Result Pass
  • Odometer reading 77,470 miles
  • MOT test number 6282 9821 1265
    Nearside Front Tyre worn close to the legal limit (4.1.E.1)
    Offside Front Tyre worn close to the legal limit (4.1.E.1)
    Rear Exhaust has a minor leak of exhaust gases (7.1.2)
  • Test date 16 July 2010
  • Expiry date 10 August 2011
  • Test Result Pass
  • Odometer reading 73,483 miles
  • MOT test number 6305 8739 0160
    Exhaust has part of the system slightly deteriorated (7.1.1a)
    Oil leak
    front no plate started to deteriorate
  • Test date 17 July 2009
  • Expiry date 10 August 2010
  • Test Result Pass
  • Odometer reading 66,031 miles
  • MOT test number 5349 0849 9155
    Rear Exhaust has part of the system slightly deteriorated (7.1.1a)
    Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
    Front brake disc slightly pitted (3.5.1h)
    Front Brake pad(s) wearing thin (3.5.1g)
  • Test date 16 July 2009
  • Test Result Fail
  • MOT test number 6202 6709 9155
    Nearside Front Suspension arm has excessive play in a ball joint (2.4.G.2)
    Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
    Offside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
    Nearside Front Road wheel bead rim badly distorted (4.2.A.1a)
    Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
    Rear Brake pad(s) less than 1.5 mm thick (3.5.1g)
    Rear brake disc slightly pitted (3.5.1h)
  • Test date 11 August 2008
  • Expiry date 10 August 2009
  • Test Result Pass
  • Odometer reading 59,104 miles
  • MOT test number 2329 1412 8226
    Offside Front Road wheel with a slightly distorted bead rim (4.2.A.1a)
