new to cruise control
Car  Clio 182
righty guys my first clio problem.
got my 182 now and while on the long drive home figuered id try cruise control. fucked if i kno how it works though.
i press the button for the green light to appear on dash to set a limit and use the steering wheel controls to find a speed,. that bit works, however upon releasing the button on the dash it forgets the speed and switches it off... is the dash button supposed to stay pressed in? or do i have a fucked button.
me thinks 3 months warrenty will be used...
you just press it when you're at speed and that's it, the +/- is so you can adjust the speed you're at without touching the pedals
You leave the dash button pushed in, and cancel/resume cruise with the button on the right of the steering wheel. Cancel/resume will remember the last speed set. Pressing the left button will set the speed as your current speed and engage cruise.
in that case i think its broke, the green light doesnt stay on once its pressed it just comes up with SET_ _ _ and when released the green light goes off
Turn cruise on so the green light appears. Press the + button when you're at the desired speed. Thats it! Then use the +/- buttons to adjust the speed, use the R button to resume after cancelling and the O button to cancel.
Sometimes the dash button does pop out. I've read about it on here at least. Perhaps your dash button is f**ked. Does the speed limiter work?
EDIT: as above TBH
