New windscreen quicky...
Da
Car  Less
Would AutoGlass need to remove the wipers and scuttle panel in order to fit a new windscreen?
Cheers!
I'm sure they just cheese wire round it and lift it out. I've had a couple and don't remember them taking anything off.
yes if they never they have just lifted the two ends with a blade box at each end and have sliped it down under it .witch makes the glue line split and can give wind noise
Cheers Lee, that's what I thought.
It's just that since I had my new screen fitted two weeks ago I've aquired an annoying intermittent squeak from one of the wiper stalks!
or worse crash the car and the air bag forces the screen out and air bag
if the screen has been fitted by pushing the screen under the scuttle panel then the glue will be pushed down with the glass and 9/10 done like that wont even be glued in at the bottom .and a air bag works with the screen to push the air bag in ya face . and good chance of wind noise
Cheers, I get ya now :)
There's no wind noise and I've had the scuttle off myself and all looks perfect, just this annoying little squeak from the wiper stalk! :(
at least you know they took it off . take the wipers off . bit of wd40 and back on give that a go
