Newbie control questions - how do I....
Hi everyone,
I have had my mk2 for about 5 days so far, its averaging 79mpg at the moment which isn't bad, anyway I have 2 'how do I?' questions with regards to the controls of the car that I can't seem to figure out:
Question 1:
How do I flash high beams when I have my lights on (or they are on automatically) - example is to flash someone to thank them for waiting so I can pass through part of the road (eg if there is a car parked on one side of the road). I know with the lights off I just pull back on the headlight stalk and it flashes, if this is done when the lights are on it locks it into high beam rather than just a quick flash. How do I simply just flash someone to thank them without blinding them? Seems odd to need to lock then unlock the stalk out of high beams.
Question 2:
Single windscreen wipe, on all of my previous cars there is a way to have a single wipe of the windscreen when say in the morning there is dew, or indeed when its light drizzle where you don't actually need the wipers on. How do I just activate a single wipe without turning the wipers onto intermittent/wipe?
  Many.
Ha, you can't actually do either of those with a clio.
I've just got in the habit of double hitting the headlight flash, and the wipers just flicking it down and up, although I have auto wipers that work properly so rarely have the need.
You can flash the headlights on, but it depends if you're using auto-lights or not.
If you have manually turned the lights on, you can flash without them stayin on. However if the lights are on automatically, I found it just triggers it on, then you have to pull it again to turn it off.
As above, with #2 you cant, unless you just go up once and then bring it back to off.
Willo40
  M135i
Averaging 79mpg?.....................:eek:, auto wipers are a pain in the ar*e, one of the very few things I don't like about mine, but I can live with them....
Willo
  Many.
I manage to half pull my light stalk back so it doesn't click in and just flashes
Without auto lights I assume? The inital stage of the stalk clicks in a relay with auto wipers on. Bit of a design flaw.
Willo
Obviously diesel lol, quite easy when driven carefully (or perhaps just not lead-footed like I do). You can turn them off with Clip, however I found using rain repellent really helped with the working of them. I think its mostly due to the delay.
  AB182, Audi A5 3.0
to wipe windscreen once just do a short press of the window cleaners. it will spray nothing and give you a single wipe.
also is 79mpg a typo? because that's not right...
