Newbie looking for a Clio 172, pros and cons?
  Clio 172
Hi,
I'm new on here. I currently drive a Mk5 Fiesta Zetec S. I have seen a 51 Reg 172 that is immaculate and low mileage. Please could you help me out with what is common faults on these and what I should look out for?
  Fiesta ST-3
Make sure it's had cambelt done and aux belt. Other than that just wear and tear items like any French car :)
  Clio 172 & Toyota Verso
Agree with above
Had mine 2 1/2 years, an absolute blast in every way
Liked it that much, now getting a new RS Megane
If it hasn't had the cambelt it doesnt matter its just an excuse to get another 4-500 off. You can always get it done after you've bought it.
An yeah just check for general wear and tear, also makesure the car pulls even harder at 5k rpm, if not stay away.
  Clio 172
Thanks guys, It is a 51 reg but only 13k on the clock.
Its only been used as a weekend car for the first 3k and then it was stored for years, has been used over the passed year adding 10k.
I cant imagine its had the belts changed but they will need changing coz of age anyway wouldnt they ?
cheers
  Mountune Tractor
cheers
Yes they would, 5 years or 72,000 miles
  275 Trophy
Yeah it will need doing more than likely. Every 5 years/72,000 miles but the aux belt is supposed to be 36,000 miles. Next year it should really be on its 3rd cambelt.
  Clio 172
how much do these normally set you back?
also, what the common problems with the 172?
How much would a 51 reg 172 with 13k normally go for on here ?
R-Sport.
  Mint 1*2's for sale-
To be fair its unusual to find one sub 40k let alone 13k-
A 51 plate minter on average miles would be high 2's low 3's to I guess your looking the thick end of 4k
S
  RS RIP
best upgrade will be good suspension, although the OEM suspension does quite well when not too old
No cross-overs i think.
Read up on matched inlets (inletmanifold) , it's mostly a very good mod. And a Fastchip Remap or tunerkit (www.fastchip.nl)
Ofcourse exhaust-mods. Decat with remap + inlets will satisfy you enough without spending mega-bucks (throttlebodies/supercharger,etc.)
Bluebeard
  Whichever has fuel
If its sat for that long, i'd make sure you go over it with a fine tooth combe!
Rubber perishes when its not used so check door seals, coolant hoses, tyres, cambelts, aux belts, wipers.... loads basically!
  RS RIP
problems;- dephaser (has to do with the VVT)
-oem exhaust = absolute waste
-rattling inside cabin
-lower balljoints go alot
-driveshafts
-gearbox , look out for this !! needs to be smooth everywhere in every gear or do'nt touch !
i have not had any of the above probs , except for the rattling cabin noises and the lower balljoints
lemonnobby
when youi go for a test drive listen for rattles sometimes low miles can be worse then high milers imo brakes can czease and rust, exhaust proberly has fell a part i would go over it very thoughly
  Clio 172
Bought the car, been dropped off on sunday. Was an absolute minter. Never seen a car in such good condition and especially for its age!
£3800 for 51 reg silver 172 with 13k on clocks
  Westy. MX5
Congrats. on getting you Clio. If it has Renault S/H then thats a good buy. If belts do need doing then make sure it's someone who is used to 172 cambelt changes, trusted Reno specialists are listed on the site, there must be one near you. Many happy miles to you.
