no power when lightly accelerating?
Car  Renault Clio 172 Ph1
i have a ph1 clio sport 172, when your lightly accelerating the car has no power and seams very lean, if you press the accelerator abit more all power is back and flys, can anyone help??
Might be spark plugs or something to do with ECU. Mine used to be a bit jumpy at low speeds when starting from cold but changing the spark plugs sorted it. My mates old Clio had really bad problems with power dropping out though which was something to do with the engine management system.
I would try changing the spark plugs first though as I changed mine and made a huge difference.
thats just like this, only does it when its cold...
what make spark plugs would you recommend? original renaults? or aftermarkets? looks a big job to change them as there under the inlet, cheers
This was happening to mine...get it on a diagnostic machine.
It said the o2 sensor before the cat was knackered I have just changed it and my car is back to normal :)
