Wonder if anyone could help me, the front right and rear speakers decided not to work, when i turn up the volume to max on the headunit , i can just about here the music. and hissing noise.
If they didn't work after you turned the volume up it would suggest you've blown the speakers or headunit.
If they didn't work while the volume was turned up but do once it's turned down then the headunit is likely clipping the signal to the speakers or going into protection mode due to excessive heat in the unit or out of specification speakers.
Thanks for the reply, I've connected the speakers to an amp and they worked for like 2 days then they stopped working again, connected it to a different amp same problem stopped working after a few days. you think there's some wiring problem from the speakers that is killing the amps?
