Noise when pulling away..?
  Liquid Yellow 182 FF
Okay, so in the last week i've had a strange noise happen sometimes when I pull away and I cant for the life of me work out where it is coming from..?
Basically when I pull away in first gear it's like a high pitch kinda juddery noise, lasts for like a second on two? So hard to put my finger on, but I know if i take it our local Renault specialist their guess will be as good as mine? Cant be my clutch as its pretty much brand new.
Any ideas?
  Alpine GTA Turbo+182
If you are getting a whirring scrupy (!) noise as the clutch engages, it is indeed the clutch. What make of clutch did you fit? Was the flywheel checked? Noisey clutches are quite common - nothing to actually worry about. Sometimes goes if you give it a bit of stick!
Stu.
  lots of clios.
my cv joints fubard and when i pull away its like a vibrating noise when pulling away? maybe that?
Im not sure what was actually fitted, my clutch was changed at a place called Mr Clutch, the car drives fine, and it doesn't happen all the time, ive just noticed it a few times in the last week, its a hard noise to explain, like a high pitched, metal shudder noise, ohhhh!!! ffs, so hard to explain a noise!
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
There's your problem right there... no seriously - Mr Clutch!!! You might aswell have taken it to Kwik-Fit!
Take it back and make them sort it but expect a barrage of BS reasons as to why its not there fault or there parts.
Okay, but that's IF its my clutch, it doesn't sound like or feel like its my clutch though.
