Tom
								i3
				Ok to make it easier lets have one thread on this from now on.
Ok first off, How do you fix bugs on your Nokia?
Easy way:
http://europe.nokia.com/softwareupdate
Follow the instructions and update your phone, most if not all new Nokias are supported.
REMEMBER! You must back up your phone before doing this as it WIPES it clean.
Sometimes you may have the latest software but still have issues, this is because your network or operator has customised the phone with special software.
90% of the time this "special" software causes more issues and makes the phone run slower.
To remove this you need to "De-brand" your phone, this is fairly simple but varies between nokias. Im putting together a guide for this for S60 phones and then later S40 phones.
Please use this thread to ask questions on problems/issues with nokia phones
Forgot to mention, to get your firmware type *#0000# if you include this in your post the clued up among us can help you easily.
Debrand S60 Guide (N- Series, E-Series, Navigator Series)
The Guide:
1. Ensure that you have installed the Nokia PC Suite (on the CD supplied with the phone), make sure that your phone is connected via the USB cable and that it has been detected.
2. Download the following 2 pieces of software:
3. Install Nemesis Service Suite. Open the program and then click the "Scan for new Device" icon in the top right of the screen. The screen should then be filled with information, click the "Phone Info" button at the top of the screen. Then click the "Read" button. Amongst other things this will show you the current product code of your phone. You now need to change this to a generic Nokia code. A standard code for the UK that you can use is 0534841 (N95 ONLY), for a full list of codes see The Nokia Blog. Replace the current product code with this new code. Then check the enable box and click the "Write button". You have now changed your phones product code! You can double check this by clicking the read button again, this should show your new product code.
4. You may at this stage wish to back up you contacts/files to carry over to the unbranded phone, to do this use Backup utility within the Nokia PC Suite.
5. You now just have to install the new firmware update. Make sure that you phone is connected to you computer through the USB cable and then open the Nokia Software Updater that you previously downloaded. Follow the step by step instructions and install the new firmwear. Do not at any time disconnect the phone until it tells you that it is safe to do so. Note the phone will restart itself during the update process.
6. That's it, you phone has now been debranded! You can now restore your files/contacts by going back into the Backup utility, however I suggest that you do not restore settings to the phone as this puts back some annoying operator defaults such has changed menu layouts.
7. If you wish to update your phones firmware in the future you simply need to use the Nokia Updater as usual as your phones product code will not need changing again.
Easy way:
The Guide:
