Rhys182 said:1st off you need to take the plastic tray off from under your engine (4 easy to undo clip things). The 'drainage point' is the sump nut on the sump at the bottom of the engine (best off putting a new sump nut washer on). The oil filter is at the front of the engine, near the top but its a b*tch to get to. Best off removing the fuel rail protector (using a long nose 10mm socket), even then its still tight unless you've got the arms of child.
5 litres of oil will do.
Hope this helps
Fred2001Dynamic said:change the filter
Rhys182 said:If you don't take all the tray off you're likely to get a nice collection of oil sitting in the tray. When neally all the oil is drained the the oil flow doesn't come through just the sump plug hole!
Andy182Cup said:What are you guys doing with the waste oil?
Leeshez said:When i changed mine i took the air con pipe off with a 10MM spanner and used a filter removal tool and as for the sump there was a little cover witch just uncliped and i used a square bar from a door handle internal mechinisam.
Leeshez
Who are you calling tight? The car was jacked up and i could not be botherd to go and buy one LOLMRBILLYUK said:^^^^ nice bit of ingenuity ^^^^
Either that or your a tight git ,lola couple of quid from halfrauds for the 8mm square sump plug removal tool if you don't have a spare door handle knocking about !
.Griff. said:You don't need to take the tray off at all..
